I just finished ripping and tagging my Dohnanyi box set and decided to dive off the deep end with Harrison Birtwistle’s Earth Dances on my Nova. But - perhaps because it has something against contemporary music - the Naim app wouldn’t play it. It simply reported a work of 0:00 length and did nothing. It also shows the title and artwork for Boulez conducts Ravel.
Note - I said the Naim app. When I tried to play the same piece on my Nova using the JRiver JRemote app the music started up as it should. On the other hand, when I tried playing the work on my QB2, the Naim app still reported a 0:00 length track and did nothing. I tried playing several other works using the Naim app without a problem, including several tracks from the Dohnanyi box set.
It also played through my Wiim streamer using the Wiim app.
I’ve restarted the app several times to no effect.
Any thoughts.
Edit - I reset the app and that seems to have solved it.
