I’ve had a bit of a search of the forum but can’t find my answer. I’m trying to stream music off my Unitiserve and 2 other attached network servers. I am able to navigate to either of the 3 devices from the Focal Naim app on my phone via my Qute2 and play a track but I cannot then navigate back up the file structure to select any other music. It just gets stuck on that song or album. I can stop the track using the handset and then navigate in the usual way but the app is still stuck in the same folder. The only way I can break out from this on the app is to press home which takes me to the various input source options on the Qute, go into settings and reset the app.
I powered off the Qute2 and the Unitiserve but the problem still persists. Any idea what’s going on?
