Naim app remote volume
Can someone share the step by step instructions to help me set up the pre-amp volume control in the Naim app please? Connecting a NDX to a 252 with the a short cable from Control to Remote 1 sockets.
I’ve used the app for years but have never seen volume control until a friend told me this was possible. I’ve always ended up controlling volume with the remote but in-app control sounds logical.
Thank you in advance.
Instructions here:
You need a 3.5mm jack to RCA mono cable. (A stereo cable will also work if you happen to have one.)
Thank you. That’s exactly what I need. I have the RCA/3.5mm mono cable so will digest these instructions and hopefully get it all set up tomorrow.
