On my Qb the App has taken to playing my playlists in any order it likes as opposed to that I specified. Have I inadvertently done something?
You’ve probably touched the shuffle icon. Just turn it off again. On and off are visually more or less indistinguishable.
Nigel thanks where is it?!
That shuffle button is a pest IMO. Mine often finds itself turned on. I’m sure i didnt switch it on either. And, it is difficult to spot if it is on or not. Id like to see an option to remove it.
Agreed. I’m sure there’s a glitch in the system somewhere.
