Naim app (V6.5) missing from App Store on Silicon Mac
Ditto…after a bit of a caper trying to find it in my list of downloaded apps.
Thanks @Paul.B for providing access to it again: very much appreciated.
Stephen
Hi @Paul.B everything is now working.
Many thanks for sorting this, and in such a short time!
Thanks all for the feedback, glad we got it all sorted quickly.
There are some flags that are required in our App Store process that weren’t quite right (they are slightly different now that Apple have added Silicon support for iOS apps on the upcoming Apple Vision Pro. I’m afraid we haven’t got any plans to try that with the app yet!)
Hi @Paul.B Does that mean that for those who have not yet downloaded the app to their Mac they will not be able to do so until you amend/update your App submission.
It should be there in the standard search now
Yep - my bad, can see it in iPhone and iPad Apps filter but not in Mac Apps filter. Assume that it will therefore load/run to a AS Mac but not Non-AS Macs as there is capability to run iPhone and iPad apps on AS Macs but not others.
That’s right, Silicon Macs only, not Intel
Once I clicked on the App icon in the iPhone/iPad list it listed Update rather than Open which it did not yesterday.
It may just take some time to propagate throughout the store, but it should be available for everyone, whether or not they have previously downloaded it.
Thanks for the swift resolution.
Roger
All updated here to 6.5 no problem on iPad, iPhone and iMac (M1 chip) all good.
Downloaded this afternoon on to my MacBook Pro M1 just fine.
ATB, J
