Hello
running an Atom wired to my home network and struggle to establish a connection through the naim app. Its working for mobiles where i established the coneection in the past but i fail to connect a new one.
any idea?
following the instruction i use the remote to push start & home as descriped. The light turns on the remote but no menu pop up on the atom itself.
The first thing to check is that your phone hasn’t connected itself to a mobile network. It needs to be connected to your home network that the Atom is also connected to.
Restarting your router sometimes helps.
If you have any wired or wireless extenders connected to your router they can cause problems if not correctly configured.
Atome wired connected to the Router. In Routersettings i find the Atom as well as my Iphone connected Wired (Router) and Wireless (Iphone).
I disabled Mobile network on the iphone to assure its not connected through mobile.
Still not working.
Following the instructions as:
- Turn on Naim Atom
- Press Play Button on Remote
- Press Home Button on Remote for 3 sec -->Navigation Button light rotates for a moment on the remote
but then search on the app does not bring any result.
Same problem here. The Naim app was connected in the past but somehow "lost’ my Atom. It doesn’t show any devices and can’t find the Atom on the network. I followed instructions as outlined above
The issue was solved!! Thanks
