Hi all,
Is this mech soldered in or can it be removed by removing ribbon cables.
I can remove the lid & i did remove a cd3.5 drawer so have some idea of how to do this part.
Thanks.
Hi all,
Thanks.
This question falls outside of forum AUP - DIY discussion. If you don’t know what you’re doing I strongly suggest you contact your Naim dealer or Naim support.
