I’ve just bought a Pro-Ject turntable to connect to my Naim Cube. Everything seems to connect physically, but I’m getting very low and crackly output. It may be something simple I need to press. It might not be. Any advice welcome - I know nothing!! Guy
Hi - has the TT got a phonostage?
As Lindsay suggests, most likely you need a phono stage.
Turntable connects to that, and from there connect to the 3.5mm stereo line in socket with a suitable interconnect.
Select analog input in the Naim app.
Is yours the e1 phono or the e1 bt?
E1 phono - put switch to “line out”
E1 bt - use line out sockets.
It’s the E1-Phono. How do I put switch to line out?
Oh my god - AMAZING!! You have saved Christmas and New Year!!! THANKYOU!!
No problem, an easy thing to overlook.
Have a good one!
Well done
