I have the option now to try a DDC usb to coaxial bridge to feed the digital signal from my Mac Mini M1 running Audirvāna into the V1 DAC instead of using the USB input. Will be assessing the performance over the next week.
Has anyone done this comparison before out of interest ?
The dac v1 usb input is said to be the best compared with the coax and optical inputs; so use usb if possible.
Thanks for the reply - interesting to know
There isn’t a specific setup guide for audirvana / dac v1 but if you scroll to the bottom of this, there are plenty of others; you might find something here.
