Naim Dacs
hi…does anyone know what naim uses for their dacs? their own production or ess sabre or something else? thanks
Naim use TI DACs (formerly known as Burr Brown) in all their digital products. Plenty of information in their literature about this.
Be aware, though, that their streamers all use a SHARC DSP which is customised to perform some of the functions that would otherwise be done by the DAC chip, so the exact model of chip used is only a loose guide to its performance.
If you use the search tool you should find as discussed from time to time.
Out of curiosity, what difference does it make? A DAC’s character /sound quality depends more on implementation than the actual chip used.
CDPs mostly PCM 1704s, selected. Perhaps the SN used a 1702 and the DAC-V1 something else again by BB.
You may find the Naim white papers quite interesting regarding DAC and various other Naim topics.
Here is a list of DACs I had posted in the past. (I think I just managed to somehow delete that old post :open_mouth:, so better to keep a copy here!)
Year Streamer Jitter DSP Filter DAC chip Analogue filter
2016 Nova SHARC 21489 (Gen4) Sells-Nilsson filter (brickwall IIR) PCM1791A
2016 Star SHARC 21489 (Gen4) PCM1791A
2016 Atom SHARC 21489 (Gen4) PCM1791A
2018 ND555 SHARC 21489 (Gen4) 6th order Sallen-Key filtration 2x PCM1704U-K 6th order Sallen-Key filtration
2018 NDX-2 SHARC 21489 (Gen4) PCM1792A discrete
2018 ND5 XS-2 SHARC 21489 (Gen4) PCM1791A
2012 NDS 512 cl freqs SHARC 21369 Butterworth w/ extra poles (IIR) PCM1704K 7-pole discrete
2010 NDX 10 cl freqs SHARC 21369 Butterworth w/ extra poles (IIR) PCM1791A 7-pole, Burr-Brown OPA42 op-amps
2011 ND5 XS SHARC 21369 PCM1791A
2012 n-172 XS TI SRC4392 PCM1793
2015 n-272 SHARC 21489 Sells-Nilsson filter (brickwall IIR) PCM1792A
2007 SuperNAIT PCM1792A
Nice, informative list, you might want to add both essential standalone Naim DACs:
nDAC: PCM1704K
DAC-V1: PCM1791A
I believe the nDAC which has 2x PCM1704K with Sallen-Key filtration, is missing off your list.
Indeed that list was not complete. Here is a more extended one with additional information; hopefully it’s readable!
Year Streamer Streaming card Jitter DSP Filter DAC chip ADC chip Analogue filter Bluetooth Zigbee
2009 Uniti Askey Computer Corp. H8NWLL3120 (not 24/192) → 2012 SeDMP3 Wolfson WM8706 No
2010 Uqute Askey Computer Corp. H8NWLL3120 (not 24/192) → 2012 SeDMP3 Burr-Brown SRC4392 Wolfson WM8728 No
2010 NDX Tecom Co Ltd. D6XWL5011S → 2011 SeDMP3 10 cl freqs SHARC 21369 Butterworth w/ extra poles (IIR) PCM1791A 7-pole, Burr-Brown OPA42 op-amps Jun15 → 2ACURBLUE
2011 ND5 XS Audivo GmbH SeDMP3 SHARC 21369 PCM1791A Jun15 → 2ACURBLUE
2012 NDS Audivo GmbH SeDMP3 512 cl freqs SHARC 21369 Butterworth w/ extra poles (IIR) 2x PCM1704K 7-pole discrete No
2012 n-172 XS Audivo GmbH SeDMP3 TI SRC4392 PCM1793 Jun15 → +2ACURBLUE
2011 SuperUniti Audivo GmbH SeDMP3 SHARC 21369? PCM1791A 2ACURBLUE
2012 Ulite Audivo GmbH SeDMP3 TI SRC4392? PCM1793 2ACURBLUE
2012 Uniti2 Audivo GmbH SeDMP3 TI SRC4392? PCM1793 2ACURBLUE
2013 Uqute2 Audivo GmbH SeDMP3 TI SRC4392? PCM1793? 2ACURBLUE
2014 muso bridgeco CX870-3B-D, FCC ID:ZQO-CX8703B
2014 muso Qb bridgeco CX870
2019 muso2 StreamUnlimited Engineering GmbH , BlueZ based host stack running on Marvell 88W8897
2015 n-272 Audivo GmbH SeDMP3 SHARC 21489 Sells-Nilsson filter (brickwall IIR) PCM1792A 2ACURBLUE
2016 Nova Naim Audio NP800 SHARC 21489 (Gen4) Sells-Nilsson filter (brickwall IIR) PCM1791A 2ACURBLUE 2ACURZIGEE
2016 Star Naim Audio NP800 SHARC 21489 (Gen4) PCM1791A 2ACURBLUE 2ACURZIGEE
2016 Atom Naim Audio NP800 SHARC 21489 (Gen4) PCM1791A PCM1803 2ACURBLUE 2ACURZIGEE
2021 Atom HE Naim Audio NP800 SHARC 21489 (Gen4)? custom 16x upsampling digital filter (IIR) PCM1791A PCM1803A two series-connected 3rd-order analogue filters (6th-order roll-off) 2ACURBLUE 2ACURZIGEE
2018 ND555 Naim Audio NP800 fixed DAC clock is also master for the streamer; fractional divider clocks to match SPDIF source SHARC 21489 (Gen4) Modified Butterworth w/ extra poles (IIR); 16x oversampling 2x PCM1704U-K two series-connected 3rd-order analogue filters (6th order Sallen-Key filtration) 2ACURBLUE upd 2ACURZIGEE
2018 NDX-2 Naim Audio NP800 SHARC 21489 (Gen4) PCM1792A discrete 2ACURBLUE upd 2ACURZIGEE
2018 ND5 XS-2 Naim Audio NP800 SHARC 21489 (Gen4) custom brickwall IIR filter PCM1791A gentle 6th-order analogue filter 2ACURBLUE upd 2ACURZIGEE
2023 NSC 222 Naim Audio NP800 proprietary DSP 705.6kHz/768kHz integer oversampling filter PCM1791A discrete transistor class-A ‘bop-amp’ 2ACURBTM1254 2ACURZIGEE
2023 NSS 333 Naim Audio NP800 proprietary DSP 705.6kHz/768kHz integer oversampling filter PCM1791A discrete transistor class-A op-amps 2ACURBTM1254 2ACURZIGEE
2024 CI-Uniti 102 Naim Pulse (StreamUnlimited 1955) BCM4362
Year DAC Jitter DSP Filter DAC chip ADC chip Analogue filter
2009 nDAC 10 cl freqs SHARC 21369 Butterworth w/ extra poles (IIR) 2x PCM1704K discrete bipolar transistor stage/ 0-fdbk complementary buffer
2013 DAC V1 SHARC 21489 PCM1791A
And here is a list of the CD Players:
Year CDP DSP DAC Comment
1992 CDI Philips TDA1541A-S1
1995 CD2 Philips TDA1541A-S1
1995 CD3 SAA7220P/B Philips TDA1541A-S1 OPA 604
1997 CD3-5 Philips TDA1305 (s-d) OPA604AP
2000 CD5 SAA7376 (18-bit 4x oversampl) Philips TDA1305 (s-d)
2003 CD5i Philips UDA1330ATS (s-d low cost)
2007 CD5i SAA7324 Wolfson WM8706
2012 CD5si PCM1793
2005 CD5x Pacific Microsonics PMD-200 HDCD Oversampling filters PCM1704K 24-bit
2009 CD5 XS Pacific Microsonics PMD-200 HDCD Oversampling filters PCM1704K 24-bit digi-out
1998 CDX Pacific Microsonics PMD-100 HDCD Oversampling filter PCM1702U-K 20-bit
2002 CDX2 Pacific Microsonics PMD-200 HDCD Oversampling filters PCM1704K 24-bit
2009 CDX2.2 (spdif) Pacific Microsonics PMD-200 HDCD Oversampling filters PCM1704K 24-bit
1991 CDS(1) Philips SAA7220 4x-oversampling digital filter Philips TDA1541A-S1 OP42 op-amps
1998 CDS2 Pacific Microsonics PMD-100 HDCD Oversampling filter PCM1702-K 20-bit
2002 CDS3 Pacific Microsonics PMD-200 HDCD Oversampling filters PCM1704-K 24-bit
2006 CD555 Pacific Microsonics PMD-200 HDCD Oversampling filters PCM1704K 24-bit
wow how many…thanks to all and happy listening
Make no mistake 1704= top dog…
That list is in error I believe for ND555 and NDX2, but correct for NDS and NDX… the digital low pass filters for the ND streamers are 6 pole Butterworth (type of low pass) filters configured in the DSP.
It is the analogue output filters that are designed using Sallen Key circuit topology… and I believe the 6th order low pass (Butterworth) filters are two 3rd order active Sallen Key filters cascaded (configured in series) in the analogue output.
Nice list.
I thought the nds uses also 2x 1704 - but seems to be nd555 only
You are right, the NDS, CDX2, CD555, Naim DAC uses two times PCM1704K. They are single channel DACs
You are right about this, somehow the analogue filter slipped in the “DSP” box as well. This is a list I have populated over the years with whatever information I come across from online reviews etc.; not only official Naim documents. So it’s likely that some journalist had written it like this and I just copied it over. Mistake now removed!
I already have 2x PMC1704K under NDS. Probably easy to misread due to the format of the table.
Happy to correct any errors you might notice. This is just myself putting information together in my Excel files, nothing official! I am only adding information for things I have read somewhere; that’s why several boxes are not populated. If something else has slipped (only 1 error so far), do let me know and I will update the table accordingly.
Sorry, my post looked a little acidic, I have edited … I didn’t mean that. I have high lighted the errors I have seen.
You might want to check the data again when you have a moment … this sort of reference is useful, and will be likely be referenced in future posts from members.
Good bit of curation… I hope it doesn’t become too arduous.
BTW I believe the network streaming modules for the NDX, ND5XS and NDS were manufactured by Swiss based BridgeCo and has since been acquired.
These streamers contain the module with FCC ID: ZUCSEDMP3 (it’s written in the rear side), which corresponds to the module SeDMP3 by Audivo, a company based in Germany.
Now Audivo at some point was a strategic partner of BridgeCo, and the 1st Gen muso had a BridgeCo CX870 network streaming module, so probably these things are a bit interconnected.
