Does anyone know where I can get some Naim DIN cover caps from.
Not the link type ones, but the ones that just cover an empty DIN socket.
If not, has anyone used an alternate cap ?
Your Naim dealer should be able to supply. It’s just for covering an unused AUX2 socket so you don’t accidentally try to connect with a standard interconnect and damage the socket.
