I could have added that when the XP5XS was discontinued I did wonder what power supply upgrade would be usable with its successor. And, of course, the ND5XS2 doesn’t offer the possibility. Perhaps the same will be true of a Nait XS 4.
Roger
Roger
I loved a Flatcap 2 on a CD5 or on a NAIT5. Unfortunately, less so when shared between the two.
Fc is the best upgrade for a 90/92 and I found it makes a substantial difference. I still have the olive set. The problem is though that an olive fc at 150-200 pounds will likely need a service at another 150-200 pounds. At 400 pounds you might find a later classic fc. I haven’t tried one with the 90/92 but it may be a better buy if you can live with the different look.
I agree totally. I had fcs on both my 90 and cd3.5 but any noticeable difference was negligible. Both I suspect needed servicing and rather than invest in the servicing, I sold the lot, and that, as they say is history. I now own something slightly better. ![]()
Another fan here, I used a Flatcap XS with my XS2 and Stageline S and preferred it to adding a Hicap DR.
With the right combination of snaics and a 4-5 interconnect you effectively end up with 4 dedicated power rails for the Stageline and the XS2’s preamp
Is there a Flatcap DR in the works?
Very unlikely, but I’m sure they would sell a lot them if they did.
Maybe - who knows ?
Guess Naim have a number of new products on the test bench - they probably always have, maybe in new cabinet design. - Those Solstice boxes for PSU and phonostage did certainly looks the business, much more than the odd TT platter.
Maybe the xs range will morph into the half-width cases the solstice power supply came in… a return to half widths for the sub classic series would be pretty cool IMHO…
Same here, I preferred FlatCap XS to HCDR on my Nait XS1 & CD5XS. I’m just not sure it was £1k worth of SQ improvement, especially as that would almost bridge the gap to a SuperNait.
Roger
A SN3 is in fact where I went next!
@Tosh1066 Have you found one yet?
Just thinking back to how many models were in the XS range once, integrated, pre/pwr, tuner, CD, PS then network player with it’s own PS and network pre (remember the 172). Naim certainly don’t offer much of a range to the mid market anymore, with discontinuation of NAC 272 and 202/200 and now Flatcap. With a one year old XS3 to go with my CD5XS my next step was looking like a FCXS but running out of options now
There’s a chance you will still find a new FCXS at a Naim dealer. It would make a very fine three box set.
I once asked for a demo of a 282/250 and the dealer only had a FC, it was very good.
A 282 is a little up tight with one compared to a hicap but not too shabby.
I’ve always preferred Flatcaps to help power CD5X/XS range.
Hicap is better on preamps.
Yup, that was exactly my experience when I had CD5XS/NaitXS. Some like the effect of a HC on XS range but I found it made the system sound unnaturally forced, at least to my ears. The FC simply enhanced the sound albeit modestly.
Roger
