After a week or so and with new leads I guess it will take a few days to come back on song.
Regarding the Witch Hat Morgana cable I’m sticking with my current hat pin 4 and Phantom speaker cable as it sounds really good and I dont want to upset the balance.
Hi Richard,
what are your thoughts about a medium level at the bottom and two standard levels above it? The heaviest unit would go on the base and lighter ones on the higher levels.
It is really well done. Quality carpentry and fittings.
It’s not easy to compare sound-wise as transferring the system means dis-assembing and rebuilding so contacts get remade, components are powered down, cool and are then restarted etc
Overall I’m really happy with the upgrade…
Can’t remember the name but it was a metal frame and glass shelving rack I bought from the Sound Org maybe twenty years ago. Maybe not state of the art but the Sound Org don’t generally sell stuff that doesn’t sound OK. The reason for the change was partly sound and partly aesthetic …
That looks super. Very nice indeed. When you take it apart to tighten it up in a couple of months, which you will need to do, you should have the very bottom shelf as the top of the base level. Then turn the one you currently have as the top of the base upside down and use it as the bottom of the base. That way, you won’t see the cutouts for the cups, which is the way it’s ‘supposed’ to be installed. You also need Fraim Chips or similar to stop the spikes biting into the floor. It will sound better too. When you fit the chips you can maybe rebuild the base.
