Hi,
Is there a way to integrate Naim Classic line of separate preamp/amp with google assistance/home or apple Siri/home? How?
Thanks!
Walter
Hi,
Thanks!
Walter
No.
You could use a Chromecast audio, that would play what you asked Google to play.
Volume could be controlled through a Logitech harmony hub, linked to a Google assistant.
Probably not worth the both, given the sound quality of a Chromecast and a remote control is much easier!
Thanks! That is a possible solution but as you say not optimal. Would be a great add on if Naim develops “another small box” that can provide that functionality to its separates.
Walter
