Naim Internet Radio - Feedback & Requests - Part 18
A repeat of the opening post from Part 1:
At Naim, we understand that while many people use our products to get the best listening experience from their own music collection; sometimes you simply want to put the radio on and let someone else choose. We’ve offered a comprehensive internet radio solution for some time, and we are now delighted to announce the launch of our own in-house internet radio solution.
In a collaboration between XPeri and our team here at Naim, we have brought the internet radio server in-house to be maintained internally, as opposed to relying on a third party as with the previous server. This will improve reliability and has opened up a host of improvements to the service, detailed below:
- A selection of over 45,000 stations worldwide
- Advanced metadata feeds for artist, track and album info on many stations
- Focus on high-quality audio streams
- Improved station categorisation
- High-resolution station artwork
- Automated station scanning
- Station podcasts (where available)
The Focal & Naim app will identify any favourites and presets that should be resaved to use the new server.
These updates are not only improving the internet radio server but improving our streaming capabilities too. TIDAL’s new 24-bit, 192 kHz streaming tier, TIDAL Max, is now available through both the Focal & Naim app and TIDAL Connect.
In a significant update for our Chinese customers, Q-Play is now supported in Naim products. QQ Music is one of the largest music streaming services in China, and users are now able to select their Naim streamer from within the QQ Music app for a seamless listening experience.
Naim Audio – Software team
With the launch of Naim’s new Internet Radio service (see above), I’ve created this dedicated thread where information can be posted relating to the service and members can post feedback and requests for the team at HQ.
Examples of how this thread can be used;
  • Announcements on key new stations / station rebrands etc. For example recently a big change in UK for Bauer Media and Global. Scala radio rebrands to Magic Classical and about 16 other new or existing stations changing.
  • request stations that we don’t have.
  • issues with a station. Eg, wrong meta / won’t play and so on.
  • notifications of any downtime on either our system in a given region, or a dependent system like the xperi live radio meta.
  • Search issues. We have the station but its hard to find as needs more tags.
  • feature requests / feedback / general radio gossip
Please ensure posts here are ONLY feedback re. the new Naim radio service or station requests. Thanks.
The latest April Update can be read here:
Hi all,
Just a few updates to mentioned.
DR Radio, Denmark. The national broadcaster has moved all their legacy MP3 streams to a different server. In the directory they are considered the “SD” (standard definition) streams. It took us a bit of time to work out what was going on but all sorted now.
113.fm, USA - Playlist based network have switched to a different CDN and it’s all a bit of a mess at the moment. We’re slowly unpicking it :slight_smile:
Best regards
Steve
Hi @Stevesky,
I’m having a strange issue since few days ago. There is a time gap of 1 hour (backward) when listening to ICI Premiere Montreal. ICI Musique Montreal is working fine and perfectly syncronized. Device specs : Mu-So Qb gen 1, streamer version 2.1.10. Any clue ?
Thanks for looking at it.
Hi @AlainG
I think what has happened is that they have introduced timeshifting support in the HLS stream and the older Muso1 has a problem with it.
i’m pretty sure that they have a legacy stream so will investigate and will update the system so older and new products can work to their best ability.
Will report back shortly.
Best
Steve
Can somebody fix it
Hi @goranp
The Beograd 202 has two streams. It indicates the legacy mp3 one has been switched off by the broadcaster.
Try the ‘hd’ variant as that is operational. but its actually encoded as a video stream so may not play on older products like a muso 1 or green screen streamers,
Steve
Hi @AlainG
We’ve added a legacy MP3 to the directory for the older products. In the directory its marked as the ‘SD’ variant.
Best
Steve
Thank you
I have NDX 1 ,I must try with FM aerial .
Hi @Stevesky
You’re the best ! It is solved. I found the new stream is marked as HD, while the legacy as none.
Many thanks again !
Alain
Hi Goranp,
We’ll keep looking to see if a legacy stream re-appears for that broadcaster. Unfortunately most major broadcaster are slowly switching to HLS streams and sometimes they configure them as video streams, even though the video is nothing. It creates increased compatibility issues with older audio devices.
Best
Steve
2 posts were merged into an existing topic: Naim Internet Radio - Feedback & Requests - Part 19
Feedback & Requests continue here:
