Hello im considering purchasing the Mu-So Gen 2.
I have a question regarding the optical \ Toslink connection. I know most applications would be to
connect the toslink to the flat screen TV. However can the input be used to convert signls from a CD Transports toslink output for CD playback?
Yes, it’s fine for any 2 channel PCM s/pdif signal, so a CD player is perfect.
Thank you Mr. Dane!
I use mine as a sound bar for tv and causal listening in the lounge - connected by hdmi.
I think it sounds really good for an “all in one.”
Gary
