Naim multiroom options?
Evening.
I’ll have a spare NAP100 that can now go in the kitchen, is a DAC V1 best bet for multirooming from Atom in front room?
It will all be tucked away, any other options?
Keep it tidy and just get a Muso Qb?
Not sure really?
Thanks.
How about 2nd hand Unitiqutes?
You will need speakers but plenty of choice out there .
Yes thats another option, just having a UQ and sell amp maybe.
Is the multiroom function any good?, no experience at all of it.
Doesn’t support Naim multiroom.
The V1 isn’t a streamer and cannot multiroom in the way you may hope. I’d sell the 100 and get a Qb. They are ideal for a kitchen, though keep crumbs away from the volume control. I can also confirm that the grilles are washable in warm soapy water.
Yes, multi room is very useful, but it is worth pointing out it is way more consistent on the gen 2 streamers compared to the classic green screen kit. I use it to have music around the house, without having to have the volume up high.
Thanks all! Leaning towards the Qb as @HH suggested… the Nap would be plumbed into some old Dyns which prob wouldn’t work in the kitchen … sound great for summer parties though?
Any good?
It’s terrific in my opinion.
I use it pretty often for playing my New Classic system in sync with Muso-QB’s and 102 streamer amps in my Australian setup.
I love it :slight_smile:
Just bought a Whiim, on a whiim … lets see how it sounds?
Wiim Ultra
NAP100
Dyn DM 2/7
Wiim Ultra vs Atom HE A-B.
Best description would be only tweeters working on Dynaudio Evokes, but the tweeters have been swapped for small bean tins :joy:
@Richard.Dane … never believe the hype eh?
Oh dear…
