Good evening.
Is the preamplifier that was designed to match the NAP 110 power amp the 42? Anyone who knows the history of Naim will surely be able to answer me.
I wonder if there is a preamp with a dedicated CD input in the Chrome series.
Greetings
In your opinion, is it correct to place the preamp and power amplifier so close together? In many racks with components of different brands are placed at a safe distance.
Seen so side by side they are perfect and with great aesthetic appeal.
Correct HH. I use my CD player through the tuner input of my early NAC72⌠and my tuner through the tape1 input ! âŚ
I was assured by my respected dealer that the tuner input was the best for line-level stuff because it has the shortest path through the amp. I am mainly a CD guy, so it goes on the tuner input
My entry into the world of Naim was the 42/110 combo, which was the entry-level back in the early 80s. You could add a SNAPS if funds would allow. I kept this for many years, upgrading to a 32.5/140/HiCap set-up. The 32.5 could be fitted with two cartridge boards or a line-level board, which I had so I could have both a tuner and CD connected.
The 42/110 was my starting point too, back in 1983. Iâd saved some of the cost but needed to borrow a bit; you had to borrow ÂŁ350 minimum to get interest free credit, so to make it work I got a used Snaps at the same time. What a fantastic amplifier it was, and how wonderful that people still enthuse about them nearly 40 years later. Iâm sure itâs not simply rose tinted spectacles.
I got mine in 81 or 82, to go with my LP12, Syrinx and Asak and Kan speakers. It was a fabulous system and definitely sounded better than any other combination at that price point.
A cracking little pair, the NAC42 and NAP110. Both were introduced together in 1979 to replace the NAC22 and NAP120 and initiated the use of an extruded sleeve with slide in tray. After a year the front to back depth of the sleeve and tray was increased slightly and standardised with the introduction of the full width extruded sleeve for the re-engineered NAP160 and 250. Hence the earliest NAC42 and 110 are referred to as âshort sleeveâ or âshort chassisâ versions.
