Hi all!
I’m new in Naim world and have a question. What’s happen when press and hold CD button on Naim nait 5i 2 (amp is ON) ? Volume button start blinking
That’s a way of putting the amp into Program mode - handy if you don’t have the remote handset nearby.
Otherwise, there’s also a special soak mode for service - you press and hold the cd button while switching it on to put it into soak mode. Make sure you have nothing playing through the amp. The volume will start to exercise, cycling up and down and it will switch through all the inputs. To exit this mode, switch it off, then press and hold both the cd and av buttons and switch on. Then reset it by switching off and then back on, making sure the volume is turned down.
