Naim NAP 200 + Hicap vs Nap 200 DR
Hi guys,
i need some advise for my hifi system (NAP 200 + NAC 202). As my hicap is damaged i am looking for a new component.
Should i go for a hicap dr or replace the nap 200 with a nap 200dr amplifier, the cost is about the same.
Thanks for your advice
Juergen
I’d get the Hicap fixed.
The Hicap will be a bigger uplift that a 200DR. Having the Hicap upgraded to DR spec is very expensive, so trading it in for a replacement is cheaper in most cases.
HiCap fixed, then save up for a 282
A damaged Hicap may just need a service.
Might be cheaper than changing power amp.
