Naim NAT 01 Tuner - Questions on buying in 2023
It’s a shame that the NAT 01 is no longer made
Yes , I went to buy one ( pre internet days) to be told “ they ‘ve stopped making them “ I then enquired about the Linn Kremlin “ they’ve stopped making them as well”
It turned out that both Linn and Naim used an identical key component made by Sanyo .
Obviously these days I could have accessed the dealer network to see who had one
For BBC Radio 3 in HD mode streaming offers a high quality feed, and you can catch up on concerts from things like the Proms
I would ask Audio T to demo something like a NDXS2 .
Hoping you are well
best wishes
Ian
Hello, Ian. I think that Peter Swain of Cymbiosis had one for sale recently. Give him a ring.
James Allney at TomTom Audio (St Albans) specialises in finding hard-to-track-down Naim equipment. Indeed he supplied my NAT-01 many years ago, when shortage of parts caused Naim to stop production of this marvellous piece of kit.
Hi Graham, it’s still there. I don’t have enough inputs on my Nait 50 and the quality of R3 HD is very good
best wishes
Ian
It won’t hang around for long at Cymbiosis. The NAT-01 is one of the best things that Naim have ever made.
(I tried for years to get the uprated power supply, which involved swapping the shoebox-sized NA-PST for a ‘pimped up’ XPS - known as the XPS-T. I believe that only around a dozen XPS-Ts were ever made.)
In addition to the LP12 I’m currently using with my Nait 50, I have the NAT01/ NAPST tuner also having a fine time attached
What more do I want :stuck_out_tongue_closed_eyes::stuck_out_tongue_closed_eyes:not much can I say :+1::+1:
Some hang around. Bought it from my local dealer after it was on their website for 3 months. I did enquire earlier but my email got lost in their system and we had heating and roofing problems. It is being serviced by Naim so I am hoping it will be ready soon.
My NAT-01/NAPST came back from being serviced at Salisbury recently, and is sounding fantastic again (it had been ‘drifting’ off station).
It is surely one of Naim’s best ever products.
We just have to hope that Aunty Beeb keeps FM broadcasting going.
I understand its aging legacy digital backbone needs updating at not insignificant expense… and I guess ironically it could be FM’s aging digital audio technology that kills off what is considered by many as an ‘analogue’ source. (In the UK)
I don’t think FM broadcasting will be taken down ,because of security reasons.
I agree FM will remain as a broadcast medium.
The question is how long will BBC continue its national FM service(s) as the latest RAJAR data for FM listening shows it has dropped to 29.7%.
Yes, but not always voluntarily. We had very good quality FM offered via the TV/Radio cable system for ages, which they switched off some two years ago. Only digital signals going over the cable now. Aerials / dishes are a no-go in our apartment building, so that was it for analogue radio.
The Naim tuner (an earliest production NAT05 with the Philips tuner head) was our most enjoyed and listened to source in the house. Somewhat along the lines what @Richard.Dane wrote above regarding his NAT03.
To my ears a NAT02 was at the same level as the Philips NAT05 just a bit different. I understood from my dealer that the NAT01 is miles better than both, sort of a ND5 XS2 vs. NDX2 level difference.
Wow that’s a left field argument. What are the possible ‘security’ reasons you are thinking of?
Indeed the VHF broadcast band is an internationally designated ITU spectrum for FM modulated radio stations so is protected under the UN, but yes, the question is what role the BBC will play on it.
I can recommend Magnum Dynalab ST2
antenna ,works very good indoors also,it don’t take much space .
I think you can figure it out …
I can’t? I am not aware of any security reasons to remove it, to the contrary I am only aware of national security reasons to likely retain it as a medium of accessible emergency public information under the NPSA.
Many years ago, I had a 3-way tuner shootout, each fed by my roof-mounted Galaxy-17 antenna.
They were the NAT-01, the NAT03 and the Magnum Dynalab FT101.
The 01 was literally miles ahead. The Dynalab had lowest noise on very weak stations and performed somewhere between the 03 and the 01 sonically.
It is no coincidence that the 01 was my PRIMARY source for many years, even though I had a CDS1 and a Naimed-LP12 as ‘secondary’ sources.
Simon he is saying it won’t be removed, for security reasons. Not it will be removed for security reasons.
Ok we are in agreement then… :grinning:. Perhaps clearer to say it will be retained for security reasons…
But it is also protected under the UN. What isn’t protected is what the BBC does on it in the future
The transmitter I use was recently out of action for essential engineering work. No notification was given, nor was there anything about it on the transmitter status website, but the music just stopped and the display on the NAT01 dimmed. I switched somewhat reluctantly to BBC Radio 3 HD through the ND555 and was pleasantly surprised by just how good it was. I wouldn’t suggest setting your watch by the pips as it’s about 30s behind FM, but it is a very good alternative.
