Hello all, I have been encounting this problem for a while now. On spotify my nd5xs2 streamer on wifi frequently stutters. I read that the algorithm that the streamers pull data is that it will buffer 3 seconds first before playing then pull data at a rate of min 2x to max 8x speed.
The stuttering occurs once in every maybe 10 songs, and it will only occur once in the song.
I will admit that the wifi strength in the position is not the best, but it should be more than sufficient to download mp3s. Clearly the speed is fine because the tracks play instantly upon clicking. I have tried resetting, restarting, changing routers.
Does anyone have a fix for this that does not involve an ethernet cable as it is not possible? Thank you
