I did that same demo before buying the NDS. The NDS with a lesser power supply trumped the NDX with a better power supply each time!
thanks again to everyone , at this point I am undecided between:
- take an NDS with XP5 XS
- put an XPS DR and improve both NDX and also the CDX2 ā¦
mumble mumble ā¦
ā¦or rip all your CDs to a NAS drive, sell the CDX2 and get the NDS with an XPS (or better). Not heard the CDX2 (had an olive CDX for a while) but pretty sure the NDS and NAS combo will trounce it.
Easy this, huh?
:arrossato: i have 2500 cdās ,no no i will :urlare::urlare::urlare:
Fair enough.
Iām relatively lightweight with just under 1000 CDs that had to be ripped and it took a while (months) using spare moments but now adding new CDs is pretty quick. You could start with ripping your favourites and growing from there. If it takes a couple of years does it matter?
yes, I understand, but since in the past years I have eliminated all the lpās :dolce freddo: I donāt want to do the same with the cdās ā¦ then the cdx2, to my ears, is a great player
The advantage of a proprietary ripper such as those from Naim, Innuos etc. is that they make ripping pretty painless. The only real difference between ripping and playing in a CD player is a 5 minute delay before between inserting the disc and hitting the play button.
I went from a ND5XS to ND5XS with NP5XS, to NDS with NP5XS then NDS with 555DR
So yes
- A NDS with XP5XS does work
- The NDS is a huge difference from a XD5XS, which was a cut-down NDX in a cheaper case.
The NDS is a different beast, with the DAC board and DAC chips still used in the ND555.
My recommendation get the NDS, use it with a XP5XS until funds allow a further upgrade to 555 either non-DR or full DR version.
Also get a SonoreUPnP bridge and a NUC running ROCK and use the NDS as a Roon Endpoint.
Actually, iāam using ndx with PC via upnp using minimserver and app naim on Androidā¦It works good
You listen to your 2500 CDs one at a time. So rip them one at a time.
You probably have a top 100. Maybe a top 10. Thatās a good place to start.
There is a big difference between a S level source compared to a X level source. It is impossible to predict which one you will prefer. The NDS is generally well regarded.
