Naim NDX 2 Vs Naim Unity Atom HD. I’m presuming the NDX is the better streamer? Do they share the same headphone amp. Does the NDX have a Balanced connection?
Thank you for all your help and advice. You have been most helpful.
The NDX2 is a far better streamer. It has no headphone amp, it’s just a line level source with unbalanced DIN output.
He’s right.
And a pair of RCA phonos! All of which is, of course, on the Naim website, ready to be discovered.
Yes, there’s RCA too. I was just towing the company line.
@Tyendra325 can I ask what you’re trying to achieve here? IIRC you have a Naim pre&power (282/250), a TT and CD player. Are you trying to add both streaming and headphone capability to your current system?
Asking cos you’ve started a few threads on various topics, TT upgrades, CD additions and headphone amp choices, and perhaps if you’re trying to do a few things at once, if you describe what you’re trying to achieve overall, the great and the good from here might have a holistic upgrade path, or five, in mind
… e.g. swapping out your 282 for a NSC222 gives you streaming and an equivalent or better than Atom HE headphone amp, inbuilt MM phono stage plus a power option for the rebadged Solstice (MM & MC) phono stage coming sometime. Then just plug your CD player into the remaining phono sockets, and done bar whatever new TT you choose.
At the moment I am reserching my options, having so many to consider is daunting. Thank you.
Thanks, for the heads up re the NSC222.
Does the NSC222 headphone amp have a Balanced connection?
It doesn’t
1 x 6.35mm headphone jack (Headphone 1.5W into 16)
There is a bit of information in the thread on New Classic about the headphone output of the NSC222, it doesn’t have the physical output flexibility of the Atom HE. I’ll have a go at finding the posts later if it would be useful
Thanks, that would be useful. If it doesn’t have a balanced conection, I may be better of going for the the NDX2 with a deicated seperate headphone amp. Am I correct in thinking the NDX2 is the better streamer?
That’s a great question
I don’t think there’s a clear answer, particularly if you add in the headphone amp complexity. Best to try and listen to a few things. Which can be a fun exercise if you have access to a good dealer.
Thank you.
The NDX2 is way ahead of the Atom as a streamer/DAC. How well it works as part of a headphone listening system obviously depends on your choice of headphone amp and headphones. Of course you have a wider choice of compatible headphones with an Atom HE than you do with a 222, but with an NDX2 you are free to choose the headphone amp of your choice and ensure that it’s a perfect match for your headphones. Balanced vs unbalanced is part of this consideration, of course, although I do think people tend to attribute more importance to this than it really deserves.
Thank you for your interesting post.
