I can get a NNP01 for a very reasonable price but cannot seem to find any place to get a copy of the DigiLinx software to configure it - any advise on this as I prefer not to strip it open and just use the amplification section - If I can set it to use one of the Analog inputs it would be perfect.
You might need a NetStreams Dealer Setup. DigiLinX Dealer Setup can be downloaded from the password protected dealer section of netstreams .
I bought a NNT01 tuner few years ago but still didn’t find how to integrated in my system.
It’s a Naimnet room amp, which was designed to be integrated within a Naimnet/Digilinx Streamnet multi-room system. AFAIK it can only be used and controlled within such a system, so isn’t much use otherwise.
First link in a google search gets to the software download for
StreamNet Application Suite 01.10.11 (NetStreams DigiLinX)
Is that what you need? http://netstreams.com/resource-product-line?pid=1082
Select “software and firmware downloads” under resource type.
