I’ve just moved into a new house and I need to temporarily switch my Nova to a wireless configuration. However, I can’t seem to do it. I’ve returned to factory settings and tried to set it up anew but the wired setting seems to be a default.
Any thoughts?
Did you try the normal process from https://www.naimaudio.com/product/uniti-nova/support and it’s not working? After a factory reset it should go like this:
(But you shouldn’t have to do a factory reset)
Is the ethernet cable unplugged?
Thanks, got it working now.
