Full 300 series system here on review and for the past couple of days the NSS333 won’t play anything on Tidal - only local rips. Internet radio doesn’t seem to be working either.
After a while the album art of what should be playing is displayed but there’s no sound (it’s worked perfectly for a month or so) leaving me baffled.
It strikes me this could be an issue at Naim’s end and their link with Tidal but if there is a problem I can’t believe I am the only one posting on here about it!
Obviously I have rebooted iPad and streamer, checked connections and confirmed that my tidal subscription is live and working.
No issue with Tidal playing on NSC222 - in uk. Is that where you are based?
Useful to highlight a specific album not playing, to allow others to check.
edit - see you also don’t have iradio working. Try factory reset of NSS333?
A router reboot fixed it! I have to say I was forced from John Lewis broadband (BT) on to an alternative provider as John Lewis were leaving the market. I selected Vodafone and since then I have been finding their supposedly equivalent service (top tier) less snappy.
It is costing me just £21 a month though instead of nearer £60…
It’s been running about a month until for some reason it caused this problem with Naim. At least I know what the fix is now - I wasted over 2 hours troubleshooting yesterday never thinking it could be router related because I could still play local rips from my NAS…
