Hi all, I’m looking to upgrade the mains cable on my NDX2 possibly to a Powerline, and I was wondering if anyone has upgraded their NDX2 with a Powerline and how it affected the sound ?
Ta..
Ta..
I have Powerlines on all my components and I could tell the improvement immediately. That being said upgrading your circuit to a dedicated one is worth the money IMHO.
Yes. I have used a Powerline on my NDX2 power supply (and throughout my system) and it is undoubtedly worthwhile - to me.
For me, the Powerline only made a small difference on the bare unit. If you can find/afford a 555PS DR then that is a MUCH bigger difference. Will cost a fair bit more though. XPS DR also made a bigger difference than powerline, but the 555 really is better.
