Much better now lose the centre plant and slightly closer together. ![]()
I would put in a corner brace so you can mount the Prefix,like it is supposed to be mounted.
it’s a pretty much untouched 74 LP12 so I’m not messing with the internals, it has a Lingo1 but otherwise it is stock.
Just glue it and remove if you don’t want it anymore,is my advice.
I have tried Prefix on the base board and under the LP12, it doesn’t sound right that way.
I’m not altering the LP12
I see,hope you will get good results anyway ![]()
Maybe seek Peter’s skills @Cymbiosis?
