My R-com reference remote is eating batteries. Is there a way to troubleshoot it or set it up to be “less sensitive”? I bought it second hand and it has always been like that. If not, is there technical support in Sweden that could fix it?
Thanks and best regards
Walter,
the lighted buttons on the R-com should go on with minimal movement and shut off automatically within a couple seconds of not moving it… does yours shut off lights when not moving?
How often do you have to change batteries?
It sounds like it might be faulty and in need of attention at Naim. It should not “eat” batteries. If it keeps switching on then be sure to place it on a surface with no vibration - even fairly small vibrations can trigger it to switch on.
Min behaves as you say. I used rechargeable barriers and I need to change them every 1 or 2 weeks. A few times the remote control has flashed and then stopped on its own and continue to work.
