Does the 1 have these & if so can i use my laptop app of both to stream.
If your Uniti has the later 24/192 compatible streaming board fitted, and it’s not on a very old firmware version, Spotify and Tidal will work. Spotify is via the Spotify app, using Spotify Connect. Tidal is controlled from within the Naim app.
