Naim uniti 1 / stageline
Hi folks, hope you are all well. Hopefully an easy question (couldn’t find answer anywhere) - i’m looking to buy turntable, but will my Naim uniti 1 power a naim stageline? The user manual suggests the phono din socket on the uniti will indeed do that, but on Naim website Stageline page it only says Naim uniti 2.
Many thanks
Yes, it will. Mine has been powering one for the past 12 years to great effect.
Odd that the rear panel doesn’t say “XXX in, Power out” like the other gear does. But it clearly states in the manual “The Phono DIN socket carries a power supply output intended to power a Naim phono preamplifier.”
Thanks folks, really appreciate the replies and confirmation
