Good day! I have decided to go ahead with the UNITI ATOM which I have auditioned 2 months ago. Nevertheless, I have seen the ability of the ATOM to drive sizeable speakers, just would like to get some thoughts on the following
I have a PSB Image B25 Monitor Speakers that has the following recommended specifications,
Input Power - 10 to 100W
Program - 70W
Dynamic Peak - 140W
With the above in mind, just to gather some inputs since the ATOM is rated at 40W/pc and how it is fairing if anyone has these similar speaker range setup
In regards to TIDAL vs SPOTIFY, I reckon TIDAL is preferred in view of file quality from the reviews that I have gathered. Appreciate some light on this.
Personally, I would chose Qobuz over Tidal for sound quality. I have also used Apple Music and Spotify for the range of music available and the Spotify connect app is superb in conjunction with the Uniti range, especially when you have a large family.
I’d suggest giving Qobuz a trial. After all it won’t cost anything unless you like it enough to sign up. But I’d probably wait a month or two for the system to run in, first.
I have Focal Aria 906s. Superb mids and very good soundstage. Perhaps lacking in bass just a touch but I have got used to it and really like them.
Look at ProAc Tablette too for a similar price and many folk here like Dynaudio.
If your room is a bit bigger check out the Focal Chora floorstanders.
Best bet - audition at home or at least take your Atom to a few speaker stores. You are probably at the point (where I was, depending on your budget) to go for either a bigger or a more sophisticated sound.
