Whilst fixing my update issue with the Uniti I noticed that the Core was no longer playing gaplessly from a ripped CD. I’ve repeated it across different albums and my 272 upstairs.
About 2 seconds from the end of a track it will mute, and then the next track will start.
Any thoughts? Is there a setting I have missed or something? It’s very strange to just turn up after years of working successfully.
Interesting. I suspect that doing a power off restart of just the Core would probably have fixed the problem, but it’s not an issue I have come across before.
I have a similar problem with my Atom HE and I had the same issue when I owned a Nova. It didn’t happen with WAV files, only FLAC and mine glitched at 10 sec before the end of most tracks when playing from my Uniti Core. It doesn’t do this on Roon. A restart/factory reset temporarily fixes the issue but it always returns, so the issue is either with my router(Fritzbox 7530AX), the network configuration or the Naim app. Annoying but I generally don’t notice as I use Roon, Internet radio or stream and it doesn’t occur in each of those use cases.
I was beginning to think I was the only one but your case would seem to indicate a common issue. May I ask what router you’re using and how it is configured so we can compare apples to apples?
I’ve a pair of TP-Link Deco X90. The master is attached to the broadband ground floor and the Core is connected directly (ethernet) to that. The Atom is connected via wifi and the 272 upstairs connects to the other X90 via ethernet. I let the X90’s mostly manage the network (channels etc) I just configure anything not roaming to opt out of the mesh, etc.
It works extremely well. Roaming between the X90’s is seemless, fast and stable.
Ok so that covers the wired/wireless options as our use case covers both those options. Both MESH systems. Doesn’t seem anything unusual. I happen to think that this problem is more widespread than reported because the glitches are so far into a track folks may not notice or they may be using Roon etc so the issue may go under the radar. I’m wondering whether the data logs may reveal something?
I’m also struggling with gapless playback - I have rebooted the Uniti Core and also the router and main network switch, is there a setting I need to change in the naim app somewhere?
Thanks David - I am reaching the same conclusion myself - I’m about to post another update to that post having found yet another issue! I am dreading having to re-rip everything again. Maybe I will just sell the CORE and use my QNAP NAS - I have Asset stored on it - but it is glitchy being able to read it over the network from the naim app - I had to do a firmware update and since then there seems to be an additional layer of security
You could just define the relevant folder in your NAS as Music Share for the Core (you do that in Manage Music of course). The Core will automatically index the folder and offer the music in the Naim app. But you can’t edit the metadata with the Naim app of course.
