Good afternoon! When the device is turned on, the CD is automatically removed. Not always, but often.Is this normal? If the server mode is enabled, this does not happen, the disk remains in the device.
In server mode the device stays “on” when you put it to sleep (short press of the power button) so that it can act as a server. If you put it to deep sleep (long press) then only does it turn fully off when in server mode. This could explain the difference.
The device is not in server mode or in deep sleep. Why does the cd eject by itself when exiting standby mode?
