Naim Unity Atom AirPlay on iOS 26.5
Is anyone else having problems with iOS26.5 and Naim Unity Atom over AirPlay? My connection breaks down and then I cannot play anything on the Atom. Restarting router, Naim, iPhone doesn’t solve the issue…
Welcome to the forum and sorry to hear of your woes.
My Atom is working properly so I’m afraid I can’t help.
Most streaming issues tend to be down to some setting in the router, but not always.
Do other streaming services work correctly for you?
yes they do.
I think it worth raising a support ticket with Naim directly.
AirPlay sends the stream from your phone to the Atom over the network. Might it be possible that your phone and the Atom are on different networks, maybe one on 2G and one on 5G? If the Atom isn’t cabled it’s always worth giving that a try. It’s highly likely that it’s a network issue somewhere.
Almost all modern, and most other routers for the last ten years, make the 2.4 GHz and 5 GHz WiFi networks the same virtual network as the Ethernet connected network Nigel.
I wasn’t sure, but just trying to be helpful. Any ideas?
It likely is a network issue, as you say. But the 2.4 GHz/5 GHz thing is not likely to be where the problem is.
Maybe it’s a scenario where two routers are giving out IP addresses, or a single router has multiple WiFi networks, such as home and guest. Both will cause problems if the phone and the Atom are on different networks. Hopefully the OP will get to the bottom of it.
It could be any of those, as you say.
iPhone and Naim are on the same network
