Must listen for yourself , did nothing for me!
I’ll rephrase, it didn’t anywhere near meet my expectations given it’s cost.
I personally will save for the 555DR and would in your shoes, given the rest of your system.
Worked for me. Of course a 555DR should bring more but the XPS DR really does add to the musicality of my system (252/250/S400). You hear what it does when you remove it. Is a demo possible? That is the obvious path.
I would most definitely want an XPS powering the NDX2 in a system of that calibre. (Although personally I preferred to go down the offboard DAC route rather than the offboard PSU, which is always another option.)
I’ve bought a 4TB usb drive for the music plugged in to the back usb… (all ripped from CD by a unity serve)
I’ve got Qobuz but it kept skipping when streaming anything above CD quality? Not sure why??
Is this the best way to do it? Or should I get a Naim uniticore ?
Hi Andy, just a separate DAC connected to the SPDIF digital output on a Naim streamer. The Naim NDAC was a popular upgrade for a Naim streamer, now discontinued, but plenty of them still in use like this. I use my NDX2 with a Chord DAC, as do quite a few other forum members, but there are quite a few other DACs around these days that you could choose.
I’m not saying this is necessarily a better option than adding an XPS, just a different one.
