My newly acquired xs2 shows the ability to tune radio stations. Is this indeed the case ?
xs2 what ? Naitxs2 amp or ND5xs2 streamer
The Nait amp obviously has no radio, but its remote can be used to sellect a NAT FM tuners preset radio stations if connected with the System Automation facility.
The xs2 streamer has Naim’s iRadio (web radio)
Thanks for that Mike. I’ll look into that. John
But you didn’t responded on which really you have, Nait xs2 or Ndxs2?
I have a Naim Nait XS2 as explained. As there is very little on FM where I live it’s not worth investing in a Naim Tuner or any other. Godjo
I’m not sure what the question actually is. The ‘tuner’ button lets you select a connected tuner, just as the ‘cd’ button lets you select a connected cd player.
You did not specify in your thread title or original post if you have a Nait XS2 or an ND5 XS2, hence the questions.
