Hi what amps does the xs2 draw? I’m wondering how much I can plug into the same power block as not to overload it and help reduce and ground loop hum.
I have deployed and earthed rca plug to reduce hum which has worked when using the xs2 in av bypass mode as part of a home theatre setup with an anthem mrx300 this has helped reduce a loud hum and now I’m just trying to work out if there is anything else I can do to optimise and I wanted noise.
Graham
