I had to pack my XS2 for a while to save for for phono stage to go with it.
I noticed today that when turning it off / on after a few seconds it caauses a pop in the speakers.
I bought a ground loop isolator which i tried today between my AVR and the naim and it made the buzz worse so i took it out straight away. I am worried i may have damaged something or if the pop has always been there but maybe i never noticed, is it normal?
Also, will no sources plugged in at all, there is small fizz through the tweeter but i have to put my head next to speaker to hear it, is this also normal?
This âpopâ, is this when turning the phono stage on and off? Or is this the xs itself? Naim amps are really designed to be left on, the pop might just be capacitors discharging on power down. Is it really loud or just a little pop, the latter again is normal after switch on when the relays kick in after a short delay.
How are the avr and Naim amp connected, just regular rca interconnects? Itâs likely an earthing issue, Iâm guessing the avr isnât earthed, just a figure 8 power socket?
Just through rca interconnect. Though I have bought a better cable today.
I raised it before on the forum and Richard d said same as you and suggest I buy a ground loop eliminator. Which I did. But it made it worse. Maybe itâs not a very good one.
Does it need to be closer to the avr or the naim or doesnât it matter?
You need one good source component earth. If you only have an av source that isnât the correct earthing arrangement then this is your problem. There are ways around it but they are straying towards the boundary of the forum rules. Essentially you need to establish an earth from a spare input. Best bet is to speak to your dealer.
