Any reason one can’t use a Flatcap 2 and a Nait XS 2?
Thanks, Andy
Thanks, Andy
Good thread here:
Is the connections the same as from Flatcap xs to Nait xs?
I expect so, the connections to a power supply on the xs 2 are the same as the xs.
Nait XS
Nait XS 2
Flatcap 2
Kind of what I figured, labeled a little differently, but basically same idea.
I did look at that other thread, and will probably try with and without the Flatcap2 (which I already have), see if it makes a difference. I don’t know that its ever been serviced. Seems fine.
I appreciate your comments, Andy
