Whilst I was checking out the radio channels followed the vTuner debarcle, the left channel on my XS2 suddenly stopped. Any ideas?
I use the DIN output from my ND5 XS, so I switched to phono and connected spare leads. No change. I then swapped the L/R leads over. No change, which seems to suggest the left channel on the amp is the problem. I then swapped over the speaker leads and the sound came out of the left speaker only.
Many thanks for the suggestion. i’ve just tried it but unfortunately no change. I suspect it’s going to need repairing. Just as I was about to trade it in!
OK, I’ll try the mute on/off trick - thanks for the tip. I’ve already powered it on / off several times. No change, but I’ll leave it off a little longer next time.
After powering off overnight and then multiple presses of the Mute switch after powering up, the left channel is still dead. Sad, but now resigned to having it repaired/upgraded.
I normally use the DIN input, but I have also now tried the RCA inputs. I also swapped them over (left/right) but the left channel remained dead. So I think it’s a power amp problem.
I’ll be contacting my dealer today to review options.
