Hello guys. I am using a sub with the nait. The speakers are the kef ls50 meta. How can I make sure that the speakers get all frequencies above 100hz and all else goes to the sub. The source is from auralic.
You can’t. It’s a case of dialling in the sub to add the right amount of boost below the right frequency.
The volume is controlled by the source. I set the volume of the amp to 40% and don‘t touch it.
Most subs have an adjustable low pass filter. You adjust this so that it supplements the speakers by adjusting it to cover the frequencies below the level at which the main speakers roll off.
