Hello
The 250 was working last night but today when I turn it on , it turn off after a few second and the LED show turn off two , any help is welcome
Thanks in advance
Hello
Thanks in advance
I would check the loudspeaker connections carefully, both at the amplifier and at the loudspeakers, to make there is no loose wire or short circuit (particularly a short circuit).
Does it come back on, or do you have to press the power switch again ? I wonder if the power switch is not latching hence the brief power up ?
I have to push the power switch again
Sounds like the switch is not latching - there have been a few threads on this before so worth having a search.
After several try , it’s working again is it the switch power which is getting loose ?
@Richard.Dane knows how to manipulate this power button.
Indeed I do FR…
Switch off the amp and unplug it from the mains. Then get a pencil with an eraser in the end and use it to press the button in and out a number of times. Hopefully that should clear whatever is preventing it from latching…
I followed the steps , it is Woking now ![]()
Many thanks Richard.
Do I sent it back to my dealer for a service , It’s still under warranty ?
No, should be fine. A replacement could do the same. It just happens from time to time, not sure why though. Mine did it once but never had an issue since.
Thanks all for your help
