I recently picked up an old olive 250 that was recapped in 2007 by Naim UK. Upon opening the amp I noticed the 2 large capacitors are bright red and not black like my Chrome Bumper 250.
Is anyone familiar with these caps? I ask because I wonder if I should replace them with caps recommended by Naim.
There’s no DIY discussion allowed on the Naim forum. It’s due a service anyway; you can use Naim or Darran at Class A who is cheaper than the factory but still Naim authorised.
The bright red caps were original I think. Are you sure it was serviced in 2007 by Naim? Probably worth checking with Naim against the serial number.
Ok. I will send it in for a recap. Thank you.
