66.4pF per metre capacitance
0.74µH per metre inductance
vs
NAC-A5
16pF per metre capacitance
1uH per metre inductance
So the capacitance is over 4 times more and presumably this goes up with cable length. I really wish Naim would publish what are acceptable ranges for LS cables - according to the output stage design. Moan over.
But the question is, is 0.74 per positive and negative wire, so in affect a single channel is 1.48. This could mean that you only need approx 2.2M per channel with SL to be stable and in-line with your 3.5uH figure.
I agree, but SL is around 25% less inductance than the NAC-A5. That is a big difference comparatively, so that really doesnt answer what the acceptable ranges really are according to the output design.
It would of been far simplier to say: Within this range e.g. 0.3 to 1.4 is OK providing that you have meterage of xx (hypothetically)
No that is not correct, you don’t double up pos & neg.
The review said it measured loop inductance which is the correct standard,
I just wonder if Naim agree with that result & what method they used.
Whatever the 0.74uH/m is more than the average inductance & as the amps have all moved on over a few design cycles since the first days of NACA4 & 5, I wonder how important the 3.5uH per channel actually is these days
Yeah, I asked support and got a very unhelpful answer. I just want to know if these cable specs meet the amp design spec or not. Surely they know what is inherently stable and what is not. I’m not asking will it sound good, just im not going to blow the output stage!
That was a 7m cable and they measured all of it not just a metre so inductance seen by the amp was 5.18uH, I’d take a guess a 3m pair would have a different specific inductance so as to provide enough for stability.
With the inductance it will reduce linearly with cable length, so whether you take the loop inductance or single cable inductance, a 5m length will be 5/7 of the inductance of a 7m length.
Similarly the capacitance reduces linearly with length so a 5m length with have 5/7 of the capacitance of a 7m length.
The exception to this would be if a cable manufacturer slugged the values by putting fixed components at one end of course.
Best
