I just set up a new Rogue Audio Rp-7 Preamplifier for a different system and I also have a Nait XS3 with the Narcom 5 controller for an older system. Both remotes control both pieces of equipment at the same time (increasing volume, mute, etc) and I’m wondering if there is a way to change the frequency channel on the Naim so it doesn’t receive signal from the Rogue controller or vice versa.
If not that, then could I program each piece of equipment to a different soft key?
Naim use the Philips RC5 protocol, so it’s likely here that Rogue use the same too. Are the systems located together in the same place? If so, I can see how that might be a problem.
The easy fix is to block the IR of whichever unit you don’t wish to be controlling.
IIRC RC5 does give the option to change a channel to avoid clashes. If I were you I would contact Naim support (or Rogue Support?) here and ask them.
