I need a recommendation for a friend, for a basic NAS to host his music, to use over Ethernet with a QB2, using the Naim app for control. Assume it would use minimserver and would not have internet access, except for an occasional unavoidable hardware upgrade. Say, 6TB storage, to be on the safe side.
Any Ideas?
Any of the more basic models from Synology or Asset would be fine running Minimserver or Asset, the latter being a bit easier to use. Or if you already have a computer on your network, you can run a server on that.
