Considering acquiring said streamer but I just have two questions that I can’t resolve -
- Can it be used as a dac with a cd transport; with non naim inter connects
- What comes in the box, leads, connections etc.
Thanks for any replies.
check out the naim website… it will tell you whats in the box and yes you can use it as a dac with its digital inputs - toslink and spdif
Toslink is SPDIF.
You mean Toslink and Coax.
Correctamundo sir!
