Hi All , hopefully a simple question to answer (though I haven’t been able to find an answer in the manuals or elsewhere online) does anyone know if the streaming quality is reduced on the ND5 XS2 when using Wifi v Ethernet? I seem to recall on my Muso 1 to get full bitrate etc you had to be wired.
Assuming the WiFi signal is stable, I can’t see any reason for it to be a reduced quality compared with cabled. It’s the same data being transferred (and not much data compared with video, for example).
The cabled recommendation is, I think, mostly about mitigating any potential instability in WiFi. But if the wifi connection is good, it wouldn’t be any different to cabled in terms of music quality.
I heard both streamers (the other being an NDX2) on wired and wireless connections on a 60Mbps connection running WiFi at around 20. Any difference was so negligible as to perhaps not exist.
I own a ND5XS2 I tried mine recently on wifi and thought it sounded equally as good as ethernet cable
So much so i have left it this way
It could be argued what is the best ethernet cable my answer is no cable !
